SailNet Community - View Single Post - Patching water tank?
post #3 of Old 05-08-2007
rheaton
You might want to test the tank to see if it leaks. If you have access to a preasure tester, use this. If not, perhaps you could seal the fill hole, and hold the tank under water looking for bubbles from the suspected area. If no leak, then you have nothing to fix.
rheaton is offline
