SailNet Community - View Single Post - Any Honda Outboard Experts?
post #3 of Old 05-09-2007
Cruisingdad
Best Looking MALE Mod
Cruisingdad's Avatar
Sounds similair to the problem I had on my Merc. It is a 6 hp 4stroke.
It would start fine and run fine without a load. Take off the choke or put a load on it and it would bog down, backfire, then quit. Problem got worse and worse. It was pretty new, so I could not see it being the carb... but it was.
Rebuild your carb. A few other tricks are to run your outboard dry EVERYTIME you are done for the day. I just pull the fuel supply off the motor as I get ready to hoist it on the davits. Only use fresh fuel and not last years leftover (which is difficult to throw out gas at todays prices).
Pull the plug and if it is really black, you are likely running rich. Clean it and re-gap.
SD mentioned checking the fuel filter. I have never had one clog up. I am not sure they are worth a crap as in my experience they never seem to catch anything.
I don't know if that helps, but that is what I would do. If that does not work, use it as an anchor and go buy a new outboard. Those lightweights are neat. Remember, it is a boat and it is expensive. Boating just would not be the same unless you spent lots of money to support it!!
- CD
Sailnet Moderator
My Website:
Follow My Blog at:
Follow me on Facebook:
Cruisingdad is offline
