SailNet Community - View Single Post - Head Setup?
Thread: Head Setup?
post #7 of Old 05-09-2007
sailingdog
Originally Posted by poopdeckpappy
I gotta question, shouldn't the Y above the tank also be a valve
There's no need for it to be. If you're using the deck-level pumpout fitting, the Y-valve should be closed... so there will effectively be only the hose running down to the tank... and if you're using the Whale Gusher pump to pump overboard, the deck fitting should be closed tightly...again leaving effectively only the hose going from the tank to the Whale Gusher as the only option. Adding a valve there just complicates the setup.
sailingdog is offline
