  #12 (permalink)
Old 05-09-2007
Gary M's Avatar
Gary M Gary M is offline
Gary M is on a distinguished road
You might be able to cut the nut off with a mini grinder or a dremel. Alternately if you are carful you could likely drill the head off the bolt so that it would fall through.
If you do cut the bulkhead be sure to reseal the edge with epoxy, I had to replace a bulkhead due to water running into the top edge.
Gary
