Regarding wood finishes – Gloss finishes have a higher content of “solids” in them. The satin finishes have flattening agents in them which tend to make them softer while providing their sheen. Therefore IMHO it is always a good idea to build with gloss and use the satin finish as a final coat if that is the look you are after. The label not withstanding it is always a good idea to scuff lightly between coats of finish. On finishes where the manufacturer indicates no between coat sanding required they are relying on a chemical bond to fuse the coats together. Sanding between coats provides a mechanical bond. Isn’t a redundant system what every sailor looks for on their vessel?
