The simplest way is to just
pump out all the contents and run it through a baja filter, which you can get at most chandleries, like West Marine, which will separate the water and gasoline. Be aware that if this is gasoline that had ethanol used as an octane booster, its octane level is probably down to about 82...and not suitable for use in most engines without using some sort of canned octane booster.
POST.
