We've owned our '84 LF-43 since 1993. Obviously, we like it! While some question whether it's a true blue-water boat, we've sailed ours for thousands of miles including three trips to Cuba (under "fully hosted" travel rules when that was still legal). You'll find her modified fin keel to provide reasonable speed (7 kts)and her overall weight to give you a sea-kindly ride. She's definitely a bit stingy on storage space for long distance cruising.
Significant issues to watch for in addition to the typical problems of water intrusion delamination are deteriorated chain plates (typical inspections only include the backstay chainplate which is readily visible from the back lazarette) as they're 1/2" thick above deck, but only 1/4" below the deck covers. I'd also recommend a navtec
rigging dye-check kit to make sure there are no cracks in the
turnbuckles or rod ends, especially those that attach at the masthead. You might also want to check with an insurance company if you want/need insurance coverage as many boats more than 20 years old require a special initial survey.
Let me know if you have other specific questions I might answer!
