SailNet Community - View Single Post - Fresh water and head
post #2 of Old 05-13-2007
sailingdog
I would not recommend using or connecting the head directly to a pressure freshwater system... or to your freshwater system at all... the risk of contaminating your potable water tanks is not worth risking.
The way my system is setup on my boat allows you to safely use the head sink to flush the head as the drain to the head sink has a diverter valve that allows the sink to drain into the head pump system or out the through-hull. The sink acts as a massive vacuum break and prevents almost any risk of cross contamination.
If you have a pressure water system, you can plumb the head sink this way, and use the freshwater to flush the head. Also, it works quite well for winterizing the head.
sailingdog is offline
