Thread: Engine trouble
Old 05-14-2007
Valiente Valiente is offline
Valiente will become famous soon enoughValiente will become famous soon enough
It could also be a blocked fuel tank vent line. If insects, like wasps, have built a nest in the line... you can have similar problems as well.
This one has caught me before. It's possible for some spider debris to actually form a flap that doesn't fully seal until the pressure in the vent line is "intaking" enough. This means the fuel pump is only gradually overcome. Turn off the engine and the suction dissipates...and you can miraculously run again.
Particularly as it is springtime, you may be victim of a wee critter having make a winter home in your vent line. Remove it from the tank side and blow out...if there is any obstruction, take it off the vent as well and blast it with an air gun. Run a dental pick (one of my favourite boat tools) out through the vent and check that you've got those little screens in. Barring that, glue down some screening over the external vent holes to prevent critter ingress.
