Old 05-15-2007
Omatako's Avatar
Omatako Omatako is offline
Omatako is on a distinguished road
Sorry to be contradictory but it is better to find some way of allowing the raw water pump to draw it's own water. If you use pressure to push water into the system the cooling system will work even if the impeller is shagged because the water will flow past the spinning impeller under pressure.
Better to find some way of creating an artificial "pond" to draw from like a toilet plunger head pushed up against the hull over the intake skin fitting, connected to a hose which is inserted into a bucket which is filled from the hose and which is held at about the same level as the skin fitting (gasp)
That way you'll sort of simulate the same conditions your engine will be confronted with when in the water.
Hope this makes some sense.
Andre
