SailNet Community - View Single Post - Seeking advice on taking care of some exterior wood.
post #4 of Old 05-15-2007
TrueBlue
Seņor Member
TrueBlue's Avatar
In my experience, oiled teak will not stay light - will darken considerably when exposed to weather and dirt. Oil also will not last more than a couple weeks in salt air and repeated coats will only blacken the wood even more - unless it's chemically cleaned prior to each application. Of course this becomes counterproductive.
Unless you accept the look of greying teak, apply a more durable coating to the wood - expect periodic maintenance if choosing this option. With my present boat, I cleaned all the freshly stripped and sanded teak with acetone - after using rags dipped in mineral spirits to remove sanding dust. When dry, I applied three coats of Cetol Light, followed by two coats of Cetol Clear Gloss.
The only maintenance required is once a season, scuff the surface with a ScotchBright pad and apply a maintenance coat of Cetol Clear Gloss. After three seasons - it just keeps getting better looking.
I am very satisfied with this choice - especially considering the 10 coats minimum required for varnish plus two annual coats each year . . . with SANDING necessary between each and every coat. No sanding is ever required with Cetol.
True Blue . . .
sold the Nauticat
TrueBlue is offline
