I wonder to buy a new propeller from a guy who sells a propeller previously used on a Beneteau Oceanis 343 Clipper. The seller knows nothing about the prop and its dimensions ... Is there anyone here who knows the dimension of the shaft on the Oceanis 343 Clipper?
Call Beneteau USA in South Carolina. I've asked them a couple questions about my Beneteau and they had answers. It probably won't help you but mine was built in France and has a 30mm shaft as does a friend's boat that is nearly 10 years newer.
There's more to this than just shaft size. There are different tapers on the shaft that the prop must have or get machined. If I were you, I'd pay someone at a prop shop to check things out, just like you would hire a surveyor before purchasing a boat or a sailmaker before purchasing a used sail. Use the expertise of the experts, in this case.
I would call Beneteau, they can tell you exactly the prop that come on your boat by the boats number. being made in 2006 or so it most likely has the same 3YM30 that they all came with. doubt someone would repower since it is one of the latest models Yanmar makes. would suspect the engine needs some work to get it back to top performance. worn injectors are a common cause of lower power on those engines.
Related Threads
1.7M posts
173.9K members
Since 1990
