Autopilot & Wheel Steering
I''ve used Raytheon autopilots before with good results and just fitted a new below-decks system to my Nicholson 45. Good stuff!
Either B&G or Raytheon pilots will work well for you, but I strongly recommend buying a system which is "over qualified" to steer your boat. Below deck systems typically have a lot more reserve grunt available when the going gets tough. Yes they are harder to install initially, but in the long run they should last longer and be less stressed.
Graham
