SailNet Community - View Single Post - Oil level too high?
post #5 of Old 02-27-2014
hellosailor
Re: Oil level too high?
1/4" of oil will have nothing to do with a runaway engine. The oil level has to get high enough (typically several inches) to get sucked up past the piston rings, in order to be combusted. 1/4" of extra oil may contact the camshaft bearings, may cause a little foaming, but there's no way it will cause a runaway engine.
And given normal engine tolerances, and the extra leeway added for marine diesels operating at all angles and motions, the odds are 1/4" of oil will harm nothing.
Don't panic with thoughts of runaway engines, ain't gonna happen from this.
hellosailor is offline
The Following User Says Thank You to hellosailor For This Useful Post:
L124C (02-28-2014)
