SailNet Community - View Single Post - CS36 Merlin Model Comparison
post #35 of Old 02-28-2014
boatpoker
Dirt Free
boatpoker's Avatar
Re: CS36 Merlin Model Comparison
The fracturing under the dinette/settee could have been caused by filling the starboard water tank too fast as the vent is a little small but not necessarily.
The same fractures can also be indicative of liner movement. if the fractures are confined to that area you may be all right. but you have to check a little further.
If you see the fractures at the settee, you then look for hairline fractures in the liner around the mast step, If you see fractures at the mast step you must next look for any sign of movement (downward) of the transverse frame member immediately aft of the mast then look along the bottom of the starboard saloon bulkhead for any sign of movement. If you see all four signs, you have liner movement.
I have attached a photo of very typical fractures at the dinette. If there are no fractures here then you have nothing to be concerned about.
Some of these boats have had shifting liners for years without any related failures, it's still a pretty strong boat but it's best if you are aware.
Also look at the trailing upper edge of the keel (lead) for filler or what looks sort of like like corrosion. There were some issues with poor lead alloy from Mars (the keel mfg.)
The hysterical laughter you hear as you drive a way in your"new" boat ..... is the seller.
boatpoker is online now
