SailNet Community - View Single Post - CS36 Merlin Model Comparison
post #37 of Old 02-28-2014
sailordave
Re: CS36 Merlin Model Comparison
Originally Posted by djodenda View Post
There is a crack on the starboard settee, which was apparently from the water tank being filled up to quickly. There also appears to be some settling of the liner, which is common for the boat.
Personally, I haven't done much other than add a Max Prop
Ah HA! I too have a crack in the starboard settee. Prev. Owner said it was from a rather heavy crew member that got tossed in rough weather. Always thought that seemed odd. I suspect your reasoning is much more accurate!
And I too looked around for other hairline fractures; none to be found.
And I too plan to change over to a Max Prop this season. What size did you get; 17x14?
My boat also came w/ a baby stay; detachable and rigged w/ a 4:1 line.
My mainsheet had what I suspect was the original 4:1 setup; I've seen upgraded to a 6:1. Much easier on the back! And I'm considering putting a fine tune on that! Kept the original setup/sheet for backup as well as clipping on to the boom and using it as a hoist.
CS 36M DIANTHUS
sailordave is offline
