post #6343 of Old 03-01-2014 Thread Starter
The futur Azuree 40
Originally Posted by JAndersB View Post
Yes, and the reason for me having the Opium 39 is of course that it by far is best in fullfilling all the different evaluating criterias we put on a boat.
But not all and that boat does not exist and probalby will never do either. But one should always keep an open mind
Also, those criterias change over time. And evaluation goes on in boat development.
As you perhaps remeber we looked closely on the Azuree 40 the last time, we where only one night from signing the ready made contract. I do not regret that we did not and a new version might be interesting again. I am afraid though that they might make the silly misstake many yards do and make i 1203 cm instead of 1199cm, or 403 cm wide instead of 399 cm. Could mean a lot of extra costs - for instance the new greece cruising tax and harbour fees.
Regards,
Anders
This new boat has nothing to do with the previous one, except the program. Regarding the existent model I really did not like too much the overall design (not referring to the type of boat) but what would put me away was a low AVS and a stability curve with not a good proportion between positive and negative stability. A boat that in my opinion should have more ballast to better those two aspects. A pity since the boat had a great interior.
Of course I only know what the lady from the Turkish shipyard (not dealer) had told me in Dusseldorf: That the 40 would be substituted soon by a Rob Humphreys that is known to make seaworthy boats.
Maybe you get lucky with the dimensions of the new boat. The Actual Azuree 40 has a hull with 11.99m a beam of 4.22m a draft of 2.6m and a B/D ratio of 25%. It is a bit better than on the Oceanis 38 given the bigger draft (same type of keel) but even so, low for a performance boat.
The Azuree 46 has a hull with 13.99, a beam almost identical to the 40fter (4.25m), the same draft, the same type of keel and a B/D ratio of 38%. That is a huge difference even considering that the 40' is proportionally more beamy.
I believe he will follow the same proportionality on the new Azuree 40 so you would have a 11.99m hull, if you are lucky 3.99 beam and also a comparable B/D ratio, one that will make the boat have a decent AVS a nice stability curve and that with a considerable hull form stability will gibe a very stiff and powerful boat. A very different boat regarding the actual one, except on the very good interior, I hope.
Regarding the dimensions you are absolutely right about the importance regarding price in marinas but not regarding the new Greek tax, at least in what regards visiting boats. I have been looking at it because I will sail there this year. In fact it is quite stupid since a boat with 13 meters can actually pay less than a boat with 11.99m that stay there for a month or too (boats between 7 and 12 meters have to pay for a year but boats with more than 12 meters can pay monthly).
