Originally Posted by First24
Hi There,
I have recently purchased a Beneteau First 24, fitted with a OMC Zephyr Saildrive (13S10). It seems there is no alternator fitted, and therefore I have no means to charging my battery system. Does one get an alternator for this motor, any alternative suggestions?
I believe those engines have a 5 amp flywheel alternator built into them and as an option you could get an external alternator driven by a belt on the flywheel which could deliver something like 30 amps. Your 5 amp alternator should provide some charging capabilty although I would agree that its not much capacity. There are a couple of fuses you may want to check if its not working.
