SailNet Community - View Single Post - Can Be a Big Job - Support Board
post #8 of Old 05-20-2007
DeepFrz
I don't see any reason that you couldn't cut out the rotted area and scarf in a piece of wood to replace the area cut out. If I were doing it I would sand everything back to good wood and then coat the wood with several coats of epoxy resin, perhaps even adding several layers of fiberglass cloth to the top. Make sure there is no rot back where the shelf joins the bulkhead.
DeepFrz is offline
