SailNet Community - View Single Post - C&C110 mast track separated from carbon
post #2 of Old 03-02-2014
A. Mann
Re: C&C110 mast track separated from carbon
Originally Posted by waynewarburton View Post
I would appreciate some input on a repair my 2005 C&C110 requires. Our mast is carbon and the track is some plastic embedded material. During a run in high winds we had a bad gybe causing a 3 foot long area of the track to pull out. This is the same mast the Farr40 has so there should be a few out there.
We have a couple estimates for the repair. One reputable company in the area wants to repair just the area that separated and another wants to replace the entire length.
I don't trust the track and think removing the entire length would be the best solution.
Has this happened to anyone else and how was it repaired.
Same thing happened to a 110 we raced at key west.it was a well known production flaw. They replaced the track under warrantee. Meanwhile we had to lash the main to the mast and climb above the spreaders to tie and untie
A. Mann is offline
The Following User Says Thank You to A. Mann For This Useful Post:
waynewarburton (03-04-2014)
