I'd like to get some opinions on the Jordan series drogue. There is one for sale in my area. How many of you Caribbean sailors carry drogues or sea anchors?
Thanks
M Murphy
Thanks
M Murphy
Yes, a JSD may be quite bulky, but I believe that it is more effective than the other drogues, which do not have the distributed load design of the JSD. All the other drogues need to be adjusted to the match the distance between waves, to keep them "positioned" properly.SimonV said:The parra anchor is just that an anchor, it is a last resort when all else fails.
I have only used it once and was greatfull for the rest it gave us there seened to be little if any shock loading as the rode was 1" white polypropoline ( I think that was what it was ) the whole thing fitted in to a easy to store bag. No where near the size of the JSD bulk, and I feel that would be the only down side of the JSD. There is a number of drogues on the market that take up less room, just my opinion.
The Boat was a 45' Roberts sloop called "slowcoach". The roller furler had jamed and we nearly lost the sail.CosmosMariner said:Simon, 1" is pretty big, what size boat were you on?
Yes, but have you ever tried to adjust the length of the rode on a parachute type sea-anchor under load??? It isn't really feasible unless you're letting out line. Parachute-type sea anchors have to be positioned properly, in relation to the boat, or they can collapse pretty easily. I prefer something that is a bit more flexible about its deployment.gershel said:Getting caught in bad conditions 50 mi from Bermuda, in deep water, does not mean that poor judgment or seamanship was used, but you are still in danger of a dangerous lee shore. I personally would want a way of slowing my progress to a minimum. Most case histories I've read claim 0.5kts or less with a Para-anchor. Also according to DDDB testimonials, when proper length nylon rodes are used, there are not exessive loads imposed. Chafe is definitly a problem, but knowing that, proper chafe gear should be obtained before leaving. Not doing so would be poor seamanship.
Marc
It depends on the way you setup the bridle for the JSD. If you lead the bridle fair, you might not have any problems. I don't know how you plan on mounting the chainplates for the bridle and where they would be with respect to the windvane.magnusmurphy said:One more question:
My boat has a monitor windvane on the stern. Seems to me there is a danger of something like a JSD snagging the vane contraption, and either ripping it off, or chafing on it, as the boat goes through the inevitable yawing of waves.
Any comments?
M
