SailNet Community - View Single Post - Water system
Thread: Water system
post #2 of Old 05-01-2002
gnorbury
Water system
Hmmm, if I were you I''d start tracing out the plumbing and figuring out how it all works.
When you are unplugged from dock water you will need the electric pump to provide pressure for the water system. Start by checking if the tanks are full and whether the pump is functioning (sucking air, blown fuse, ???). Also check for a 3-way valve which might select between dock water and the onboard pump.
Graham
gnorbury is offline
