SailNet Community - View Single Post - portlights
Thread: portlights
post #6 of Old 05-22-2007
sailingdog
What ever you do, don't use brass fasteners on a boat, especially on one that is on salt water.... the brass will de-zincify and then you will lose your ports. I would go with silicon bronze fasteners if the ports themselves are bronze, as you'll have the least problems with galvanic corrosion between the fasteners and the ports.
Both plexiglass (acrylic) and lexan (polycarbonate) will work for ports, but the Lexan will be far stronger. You need to make sure you get Lexan with a UV-protective coating and preferably a scratch resistant coating as well.
What you bed them with may depend on whether you go with plastic (acrylic or polycarbonate) or glass. Polysulfide-based sealants will attack lexan or plexiglass, polyureathane-based ones will not. I would bed them with 3M 4200... since it is very likely that you will have to replace them at some point in the future.
óCpt. Mal Reynolds, Serenity (edited)
StillóDON'T READ THAT POST AGAIN.
sailingdog is offline
