SailNet Community - View Single Post - water in sunfish hull
post #2 of Old 05-22-2007
yotphix
can't re member
Ahem...Not that I would have any personal experience with this, running a sunfish daggerboard into a rock could cause cracks in the daggerboard trunk that would allow water in that would not necessarily find it's way out. Other spots might be hiding behind the aluminum trim around the hull/deck joint, or under the splash coaming or the bottom of the mast step.
About the only way you will get the water out is to drill some small holes in the bottom and then repair them with epoxy or whatever you like when it is dry.
As a side note, if anyone ever wondered what a submarine sailboat would look like, a waterlogged sunfish with two adults on it will give you a good idea, and will continue to sail downwind as long as the boom stays out of the water!
yotphix is offline
