Old 05-24-2007
rperret's Avatar
rperret rperret is offline
rperret is on a distinguished road
project complete
Old banjo bolt removed easily - and seated new bolt without any problem.
Surprisingly the bleed was easy - 5 pumps and fuel was flowing from the first bleed screw - then got lots of air out of the injection pump screw.
Motor started on first crank in 3 seconds.
Current problem solved....impeller is next
MackBoring reps stated to ensure that one doesn't over tighten bleed screw - most people do which causes problems down the road.
Rick
