SailNet Community - View Single Post - Spreader lights: One or two?
post #6 of Old 05-24-2007
Giulietta
Originally Posted by groundhog
I'm afraid I have purchased the swivel lights. I guess I will take some precautions and goop up the swivel holes once I position them. I purchased the LED versions.
groundhog
Are they the same as i mentioned?? If they are, go back, and return them, if you can. Mine were filled with sikaflex and still water got in. The metal expands with heat from the light. Get the non swivel ones, the hole is on the side and if you loop the wire forming a U before it enters the light water will not get in.
I forgot to tell you I also have a another light forward in the mast, pointing down in to foredeck.
Giulietta is offline
