Old 05-03-2002
obiec obiec is offline
obiec is on a distinguished road
Air Cond. and alternators &batteries
Probably yes. Keep in mind that a 6 amp I am assuming is at 115 volts so it would be around 75 amps at your boats voltage. The problem with an inverter is not running the appliance but starting it. It will only be using around 900 watts, but to start such a load will take a much larger inverter. I don not believe a 1500 would do it I think you would need at least a 3000 watt inverter and that might not be enough. I would ask that your dealer let you take it and see if it will start the load before you purchase it. Now if you are drawing around 75 amps you also have the inefficacy''s of the chargers the inverter and the storage of the batts to contend with. So your actual consumption will be more likely to be 90 amps. This means without running the engine you would deplete your battery bank to the 50% mark in 2.5 hours. If you have an alternator that will produce 100 amps or more it might keep up or at least come real close. if it is 50 amps that you could go approximately 5 hours before you would have to shut down your AC for at least 6 hour to recharge.
