  #26 (permalink)
Old 05-05-2002
obiec obiec is offline
obiec is on a distinguished road
High Tech vs traditional-Comments?
As I stated I don''t know, I was more thinking out loud with a question to those whom might have a good response. This is why I was thinking that they might be good heavier whether boats. First of all It seams that there displacement has gone up quite a bit, and I am relating this back to being thicker glass better bulk heads and a generally stiffer frame. So I think they are going to flex a lot less? Secant with so many having roller furling as well as roller mains it is going to be very easy to select the right sail combo. Third It seams to me that there rigging is heavier also. And last the open sterns with the swim steps to me seams grate if you are knocked down or pooped there could be no better way to drain that cockpit that quickly. It dose seam like you would get your feet wet a little more often in following seas.
