Old 05-05-2002
fishclan fishclan is offline
fishclan is on a distinguished road
Remove painted name from hull
If you want the best looking and you have a good layer of gelcoat, wet sand lightly with fourhundred use a slight angle with your strokes. You don''t have to get it all but most of it. Then with sixhunded wet sand the most favorable direction. That way you will be able to see when you get all the 400 scratches out. You can''t buff out 400 scratches Then buff with a buffer at about 2500 rpms. start with 1000 grit and then to 2000 grit. Do it all the time at work. Good luck
David
