Thread: Wet deck...
Old 05-27-2007
camaraderie's Avatar
camaraderie camaraderie is offline
moderate?
camaraderie has a spectacular aura aboutcamaraderie has a spectacular aura aboutcamaraderie has a spectacular aura about
Decks on sailboats are usually made of a sandwich of 2 layers of Fibeglass with a core in between them. These days the core is often foam, but in older boats it was often marine plywood or balsa. If moisture gets down into this core it tends to spread and rot the wood causing delamination, leaks and s loss of structural strength...all bad things. Extensive "wet decks" can be a major pain and expense to repair.
