Old 05-27-2007
sailingdog sailingdog is offline
It is probably a real Cabo Rico, since it would be illegal to call it a Cabo Rico, unless it is a Cabo Rico. It is probably not in very good shape...and that is probably the reason for the low price. If a boat is significantly lower in price than its sister-ships, there is almost always a very significant reason for it.
From the photos in the website, the teak deck looks like it is going to be a problem... as does the aft deck, which has some poorly patched holes in the photo and badly damaged gelcoat. The interior also looks like it'll need a fair bit of work.
For instance, compare these two photos:
The boat you listed:
http://newimages.yachtworld.com/1/5/...?1151324505000
Another one listed for $54,000 on Boats.com:
http://newimages.yachtworld.com/1/5/...?1152886234000
Although you can't see as much of the foredeck in the second photo, it is pretty clear that the deck is in much better shape. You don't clearly see the bungs in the decking as you do in the first photo.. and the wood appears much cleaner and not splotchy and stained as it does in the first photo.
Also, the bow pulpit is clearly damaged on your boat's photos, and the stanchion and pulpit are rusting badly in comparison.
