Electrolysis / Keel stepped mast
You know metals corrode...even same metals...clean mast & mast saddle...heavy coat with epoxy paint on both...apply very heavy grease to mast end and saddle...drill small drain hole at bottom of mast just above saddle. Install mast. Water can now drain and you can spray in WD-40 to flush out contaminates and coat inner mast from time to time..
