Old 05-30-2007
jrd22's Avatar
jrd22 jrd22 is offline
Courtney the Dancer
jrd22 is on a distinguished road
The red over green lights positively identifies the vessel as a sailboat, no other vessel can display red over green(previous reply refers to red over white, which is a Pilot vessel). With lights on deck you will be identified as a "power vessel" when sailing at night. This is a dangerous situation when a power vessel fails to give you the right of way based on his assumption that you are also a power vessel. Masthead lights are a pain to replace though and add some weight and windage at the top of the mast. For cruising and ocean crossings, I'd go with the sailboat lights, red over green.
John Davidson SV Laurie Anne
1988 Brewer 40 Pilothouse
