SailNet Community - View Single Post - Replacing SeaCock Gate Valve with Marine Ball Valve
post #8 of Old 05-31-2007 Thread Starter
saurav16
saurav16's Avatar
Send a message via AIM to saurav16
Thanks for the post, I was wondering though the through hull with the flange has to be mounted on wood to get a level surface, and bronze screws need to be drilled through the hull right? Won't there be a leak the screws are going through the hull? Also If the wood gets wet that the ball valve is sitting on it will swell and rot so there won't be a good seal there. Should you use glass instead of wood?
saurav16 is offline
