SailNet Community - View Single Post - Is a propane Solenoid supposed to be hot ???
post #6 of Old 06-01-2007
trantor12020
trantor12020's Avatar
Mine is hot as well. Initially was ok for a year. After that I guess the coil get weaken by the heat and would release the plunger after 5-10 mins shutting off the gas. So to cut down on the heat, I pass the switch-on voltage to a small 12V handphone car charger and tweak it to output just about 7VDC. Just enough to activate the solenoid for gas to flow. Its no longer hot, just slightly warm. Works great.
trantor12020 is offline
