Old 06-04-2007
rperret's Avatar
rperret rperret is offline
rperret is on a distinguished road
s2 6.9 keel
I would start with asking people at s2 6.9 class association. see link below - you should be able to get input from them as someone may have had same problem:
S2 6.7, 6.9 & 22 Class Association Web Site !
Also, is the keel made of aluminum? You could probably get a local metal fabraicator to duplicate the keel - but you need to be spot on with the shape, dimensions, etc.
again, the best place to start is the link above - contact the officers of the class association they can at least point you to some resources.
good luck!
Rick
Originally Posted by Grumman
Thanks for your response.
We have a retractable keel on our 6.9 . We hit something with the keel, and the bottom half of the keel bent 90 degrees. It was a real drag!!
We had to cut the keel into pieces to remove it from the boat, but managed to leave the steel bar that anchored into the lead in tact.
If we have to we could rebuild it, but would prefer just to replace it. Any ideas where a replacement can be found? (S2 is a dead end, no inventory of old keels).
Thanks,
Jay Williams
