SailNet Community - View Single Post - PB Blaster/Penetrating Oil WARNING !!
post #1 of Old 06-05-2007 Thread Starter
Maine Sail
Maine Sail's Avatar
Hi All,
I thought I sould let you all know that I discovered, the expensive way, that you should never use PB Blaster near ANY engine or transmission seals.
I needed to remove my shaft coupling so I sprayed the four bolts with PB Blaster, thinking nothing of it, and let is sit over night. Evidently some of it dripped onto my transmission output seal and when I went to the boat the next day the majority of my transmission fluid was in the pan and not the transmission.
My transmission is a 2003 ZF v-drive and had never, ever leaked a drop. After speaking with a few mechanics about this they know the problem well. PB Blaster can eat engine seals, transmission seals and plastic cups! Keep this stuff far away from any output shafts, engine seals or seals you don't wan't leaking.
PB Blaster is great stuff but also very dangerous to the tune of $800.00 on my transmission seals. Use it with caution and for it's intended purpose only!
______
-Maine Sail / CS-36T
Maine Sail is offline
