SailNet Community - View Single Post - Fricking Project Headache #2982B: GPS mount in Pedestal Guard
post #2 of Old 06-06-2007
EscapadeCaliber40LRC
leave blank
I think you need to cut the wire. Then you can drill hole to fit the cable diameter only. It would be smart to run the cable to a block below the sole. Where you could add a splicing line to extend cable to wherever you need to run it to. I did a similar thing to mount my Garmin unit above our compass, worked out fine. Hole diameter was pretty small, attach the cut end to a jumper block. On my Garmin, only a few of the internal wires were actually used.
EscapadeCaliber40LRC is offline
