volvo engine
http://www.penta.volvo.se/t/005.asp?id=612&p=18
That will get you the parts listing. Use the dealer locator to find someone near you, you can order the parts through them. If there''s a cheaper way, I''d like to know as well (I''ve never seen a ''discount'' volvo parts dealer).
I HIGHLY suggest you don''t assume ANYTHING about your engine. Replace all the impellers and filters (or have someone do it for you) change your oil and coolant. If you''re not in the water, replace your shaft seal and cutlass bearing now as well. If you''re in the water, plan to do it on your next haulout. That way you''ll be starting maintenance on your schedule instead of it being a question mark.
Don
