SailNet Community - View Single Post - convert to fresh water head
post #2 of Old 06-10-2007
sailingdog
Put a diverter valve in the output from the head sink drain, and plumb it into the input on the head pump. You can use either a t-fitting, and continue to retain the ability to use salt water to flush, or connect it directly.
I recommend using the t-fitting, since on a longer cruise, it would make sense to flush using seawater in order to conserve your fresh water supply. By turning the diverter valve, it will allow you to flush the head by filling the sink with water. You can fill the sink with anti-freeze and use it to winterize the head, or you can fill it with vinegar to clean the head and help de-mineralize the waste lines once in a while.
sailingdog is offline
