Old 06-11-2007
sailingdog sailingdog is offline
Marc-
You can't really use a zinc in the case of something like this. You're much better off using a galvanic isolation washer made of thin plastic or galvanic isolation compound, like Lanocote or TefGel. I wouldn't go cutting grooves in the stainless part, as it might be used as a bearing surface to some degree. Cutting a gutter in it would drastically increase the wear on whatever part rotates on it.
If you are really having a problem with it... why not get the part made up by a machine shop in all stainless or all marine bronze (which is considerably easier to machine IMHO).
