SailNet Community - View Single Post - Rules of the Road: Precedence?
post #5 of Old 06-12-2007
sailingfool
ASA and PSIA Instructor
First, Starboard over Port
......Generally, IMHO, a running boat must give way to a close-hauled boat regardless, since the close-hauled boat is much more limited in the changes in course it can safely make. A boat sailing close-hauled can only turn downwind, or risk going into irons.
SD, your humble opinion may cause a little trouble if you are beating on a port tack and find yourself on a collision course with a boat running on starboard. That skipper is likely to expect you to give way per 12 (a) i. Rule 11 / 12: Application / Sailing Vessels and if you don't, you'll at least garner a nasty grimace for your failure, assuming the other skipper is paying attention. If he isn't, then it caould be ugly and not a situation you would want to explain to your insurance agent.
sailingfool is online now
