SailNet Community - View Single Post - Rules of the Road: Precedence?
post #8 of Old 06-13-2007
sailingdog
Originally Posted by sailingfool
SD, your humble opinion may cause a little trouble if you are beating on a port tack and find yourself on a collision course with a boat running on starboard. That skipper is likely to expect you to give way per 12 (a) i. Rule 11 / 12: Application / Sailing Vessels and if you don't, you'll at least garner a nasty grimace for your failure, assuming the other skipper is paying attention. If he isn't, then it caould be ugly and not a situation you would want to explain to your insurance agent.
As the OP did not specify that the boats were or weren't on the tack, I made the assumption that they were, you made the assumption they were not. If they were on the same tack, the windward boat, the one running, is going to have to stay clear of the leeward boat, which is beating.
sailingdog is offline
