SailNet Community - View Single Post - Hull speed and wide sterns
Old 05-22-2002
Jeff_H's Avatar
Jeff_H Jeff_H is online now
Super Moderator
There was a recent discussion on this Forum about why newer boats have wider sterns. In the most recent issue of Sailing World there was an interesting couple paragraphs dealing with theoretical hull speed which touched on this very issue. I thought it might be an interesting topic for further discussion since both topics (wide sterns and hullspeed are frequent forum topics). I am quoting here:
"Waterline''s affect on hull speed is theoretical and not absolute. As a hull goes faster, the bow wave stretches to the point where the bow and stern wave become on wave cycle, whose wavelength is equal to the waterline length. This brings us to wave theory. "
"The speed of a wave (in knots) is equal to the square root of the wavelength (in feet) multiplied by 1.34. If your boat has a waterline length of 32 feet, the theoretical hull speed is 7.6 knots. The waterline length is thought to limit the hull speed because if the boat goes any faster the stern waves has to move further back taking the trough between it and the bow wave along with it. As the trough moves aft, it causes the stern to drop, making the boat sail uphill."
"Except for planning designs, sailboats typically can''t generate enough power to go any faster and climb their own bow wave. But a boat with extra volume in the stern can exceed its theoretical hull speed because the extra bouyancy prevents the stern from dropping into the trough. By the same token, a fine-ended design might not achieve its theoretical hull speed if buoyancy in the stern is insufficient." (Written by Steve Killing and Doug Hunter).
