SailNet Community - View Single Post - Hull speed and wide sterns
Old 05-22-2002
SailorMitch's Avatar
SailorMitch SailorMitch is offline
Senior Moment
SailorMitch will become famous soon enough
Denr,
I''m a big fan of Sailkote. I use it for nearly everything, so I have done away with all sorts of other containers onboard. It works better than WD-40 in many applications, and is a passable substitute for it in others. Sailkote works better on my fair skin than SPF-15 sunblock. It''s slightly less effective as an insect repellant but try it and see if it works for you. I spray it on the knotmeter paddle wheel to keep crud from fouling it. In a pinch, Sailkote even can be substituted for Pam or butter when frying eggs for breakfast. It also shrinks painful, swollen tissues, but won''t go into details on that one.
As for you, I''d spray a little on the mower before each use. Can''t hurt.
Oh....did I tell you I own stock in the company? So please buy the gallon containers of Sailkote, and use it LIBERALLY!!!!
