SailNet Community - View Single Post - close reach = beating?
post #40 of Old 06-16-2007
tomaz_423
tomaz_423's Avatar
Originally Posted by chrondi
... 25 off the wind. Apparently, you mean apparent wind and certainly it has to blow above a certain level (I gather about 12 knots).
Chrondi, Giu's boat is no ordinary cruiser. Giu's hi performance sailing rocket should most likely point 25 true.
A normal "performance cruiser" can tack 90 true or better.
That is 45 true off the wind. at 12 knots of wind and 5 knots of boat speed this would be about 30 apparent.
Even I can do it easy on my Beneteau 423. The track on a GPS plotter gives you a nice picture about true angles.
Polars for my boat indicates I could do better then 30 true (but at cost of low speed and therefore no the best VMG which is if I would go 40 to 45 true - depends on wind).
Of course polars are far from real life (my bottom growth, my sails condition, my not-so-perfect sail trim, the waves and my lack of skills all make results worse...)
But consider Giu's racing background, his new and clean racing boat, deeeeeeeeeeep high aspect keel (maybe even the shark helps), racing folding prop, his new sails and add to that his huge desire to be the best in everything - and here you are: I am sure 25 is true not apparent.
Giu,
please let us know what is the angle you use to achieve best VMG ?
I would guess 25 is the angle to prove how high you can point and 30 may be where the speed builds up (in normal winds) - or am I wrong?
Beneteau Oceanis 473
finished cruising after two years.
tomaz_423 is offline
