Mark, how big is your battery bank & power draw?
The reason I ask, is because "bigger" isn't any use unless you can make good use of the power. It is fairly easy to have more alternator than you need, unless you've got a serious battery bank. Sometimes, a good external 3-stage regulator is all you need, along with upgraded cables and a better charge sensor (from the regulator to the batteries).
