SailNet Community - View Single Post - Holding tank vent..
post #6 of Old 06-17-2007
sailingdog
The holding tank is usually connected to the head and can draw air through the pump and water out of the bowl of the head on most boats. The vent is necessary to keep the holding tank from building up pressure, but isn't the only source of "air" into the holding tank when pumping it out.
In fact, I generally fill the head bowl with water just before I pumpout, and you can hear often hear the bowl being drained, and will know that the entire tank has been evacuated when the head bowl is empty. The water in the bowl also helps "rinse" the lines and the holding tank, which can help prevent odor problems from beginning.
sailingdog is offline
