SailNet Community - View Single Post - Fuel pump
Thread: Fuel pump
post #5 of Old 06-18-2007
sailhog
It's an easy switch. Might want to consider changing your fuel line while you're at it. It should be 3/8" and you can get it at NAPA for $1/foot. I just installed a clear fuel filiter between the pump and the carb, which I'm hoping will cut down on the condensation problem. As Cam said, there should be a filter after the tank as well.
sailhog is offline
