SailNet Community - View Single Post - 'nother rudder question
post #5 of Old 06-18-2007
Idiens
Larus Marinus
Idiens's Avatar
OK zirc = zerk. The usual suggestion on the tractor forum is to pump grease in until you see it coming out somewhere. It might work for rudders too, but probably only on the hard, as the grease may choose the route down instead of up. I would squirt 5 fives, waggle the rudder and maybe squirt five more. If your using a good grease gun and after a couple of squirts it goes hard (not the first one, its breaking the seal on the zerk) stop pumping or you may break a shaft seal somewhere.
Idiens is offline
